Video as an animated texture source.
hopbin9
Yes, this is possible. Someone please correct me if this is wrong. You'll have to convert the video to just single frame images first. When plugging in the image file use $F to represent which image of the sequence you want ($F is local variable for the current frame). Or use $F4 for padding of four, $F5 for padding of five, etc. An example is below to give you an idea.
Image sequence for texture:
image...
Example path for Houdini:
$HIP/textures/image$F4.png
Thanks,
I can do that, but was wondering if I can avoid having to convert the video to image sequences.
As far as I know the Texture VOP node supports only single frame image formats. You'll have to convert the video to images first. Any compositing application should handle this or if you don't have access to any you can use ffmpeg, replace the paths and width/height accordingly.
