Creating SOP nodes and list of SOP tools for using in a Python script?
kursad
Hi
What is the best way to create SOP tool nodes inside a geo node via Python? I checked the SOP tools Python codes and it looks like they use "soptoolsutils" module. Is there any other way to create SOP nodes? Also where can I get the whole list of all the available SOP tool nodes? Is there some kind of dictionary of the callable names"
thanks
Hi.
I guess you've find the soptoolsutils by right-clicking the shelf buttons. This is used just to call an exisisting op.
To make new op, like sop, you create them using the file -> new operator type.
To get you started I would suggest you to follow rdg's tutorial on creating a simple python sop ( http://www.preset.de/2007/0711/lorenz/ ). This is will really give you a good start. Then searching houdini documentation, and looking at other people python op on this forum will give you more info.
Cheers
Nico
edit:// For a list of all the ops, just right click on any operator and select 'operator type manager'...
Edited by Div
Hi.
Cheers
Nico
Hi
Thanks for the reply. I actually can work with the Python SOP itself. I am just trying to figure out how to call one of those functional SOPs and create them via the Python script, like adding a Particle SOP or adding a Group SOP before and after certain nodes.
I will look at the list of the type manager. Nice tip
thanks
