how to export Data from Houdini to Grasshopper or Excel
Hallo,
At first: I use Houdini Apprentice.
I´m currently searching for a solution to export data from Houdini to grasshopper or to exel spreadsheeds.
why excel spreadsheeds?
- because grasshopper can read them.
what kind of data?
- point/particle numbers and positions
- vertices
- in short: all data that can be shown in the detail view
(I know: that was a spongy declaration)
why not just "save geometry"?
- because all the point/particle NUMBERS are missing
and they´re so important for grasshopper!
It is so easy to get acces to all kind of data inside Houdini. there must be a way to get certain data out!
If anybody could help me I could breathe a sigh of relief!
Greetings
Fantasy300000
Since it is an apparentice you shouldn't "abuse" this feature.
If you find the software useful consider an "upgrade".
my intentions absolutely harmless!
i´m such a newbie in houdini
that i´m faaaaar away from any possibility of abusing houdini!
as i evaluate my current skills it will take me looooots of time to even follow the adwises that I achieved here in this forum - no joke!
the only risk might be that (after loooots of time time) I could interest some grasshopper users to take a look at houdini!
greetings
Fantasy
Edited by Fantasy3000
Grasshopper requires no knowledge of programming or scripting, but still allows designers to build form generators from the simple to the awe-inspiring.
What's grashopper doing you can't achieve with houdini?
I guess grasshopper is lacking particle sims and dynamics.
Grashopper is a bit like building geometry in VOPs (I hope you can say it like that).
But as a Rhino-plugin it´s laid-out for fabrication. And it´s nurbs based.
And you are right: GS doesn´t have particles & dynamics and I want to see a bit of that in it. DOPs & POPs might be the main reason I started with Houdini. It´s experimentation and I HOPE that it will be fruitful!
Houdini appeared very promising to me because you have real good controll and acces to nearly every data/parameter INSIDE of it. That´s the reason I decided to learn it. But I´m more and more getting cold feet because I didn´t spend enough time thinking about data exchange!!!
PS:
Same topic here:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=21516
http://www.3dbuzz.com/vbforum/showthread.php?187155-how-to-export-Data-from-Houdini-to-Grasshopper-or-Excel
