for each SOP
Ezz
  On 2/10/2011 at 2:49 PM, hopbin9 said:
If it worked on point attributes then it would be the same thing as a Copy SOP.
Hi hobpin9.
Thanks for you answer.
I was using a ForEach-SOP to create different groups based on a l-systems pointAttribute "gen". I could not make it
work without promoting the pointAttributes to primitiveAttribute. So I just wandered if there was a particular reason.
Thanks
Erik
