cull back face equivalents in shader
LaidlawFX
cool. I was being a meat Popsicle and it didn't work, works fine now, the dot product, too.
Is there an equivalent in vop sop too so i can use it as an orient vector. I couldn't get the dot product to work, because of the aforementioned meat Popsicle problem. There is no I vector since the vop isn't aware of the camera as I understand, and I don't want the user to have to specify it. Also transforming the p space to the camera space isn't working for I either.
you need to specify camera for VOP SOPs if you need to do such things
there is toNDC VOP to transform point to normalized camera space, but you need to specify it, if not user then maybe you can find some clever way with Python, for example with a Button Press it will find camera of the current viewport or something
you can also get transform matrix of the viewport in Python
http://www.sidefx.com/docs/houdini11.0/hom/hou/GeometryViewport#viewTransform
so maybe Python SOP can help you if speed is not the priority
or just use Python to pass that transform to VOPs
