yongbin Posted February 11, 2011 Share Posted February 11, 2011 Is it possible? I attaching my hip file. Please teach me! ogltex.hipnc Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 11, 2011 Share Posted February 11, 2011 (edited) Houdini help has an example file on it. It doesn't have it with the new shaders, but the old system works fine for most things. I need to get around and playing with it in the new shaders, myself one day. from help .../examples/nodes/sop/layer/MultiTexture.otl This example demonstrates the use of the layer SOP to layer multiple textures onto a single object. here are some Past Threads And some more docs in progress Edited February 11, 2011 by LaidlawFX Quote Link to comment Share on other sites More sharing options...
yongbin Posted February 11, 2011 Author Share Posted February 11, 2011 Hi LaidlawFX, Thank you for your reply, I tested it, but it wasn't what I think. That question above cannot express what I need, sorry. What I really want is... if i have these images. test1.jpg test2.jpg test3.jpg . . . test100.jpg and have 100 separated primitives. Is there an "easy way" to link this images to prims? any expression or node? Not in rendered image, in viewport. Thank you. Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 11, 2011 Share Posted February 11, 2011 The other method you need to assign uv spaces to each primitive assign it a uv level which you can do in a foreach loop, and then on the shader customize it so it's dynamically linked to say x_x amount of texture layers, so when you want 100 it will load then in dynamically. As strong naming convention and dynamic path could handle that. Outside of that I haven't touched ptex, but from what I understand textureing is based per primitive, so you can try something new with that. I don't know of a one step process to do this since it combines components of sop uving per primitive, and shop ogl components that are not as robustly implemented in Houdini. It's got to be a multi step process unless some one else knows better. I can try this weekend after I look for apts Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 13, 2011 Share Posted February 13, 2011 Is this what you were looking for? in ogl a 100 different primitives with each a different image. It is still a multi step process, but on the plus side it has the perk of maintaining geo space for uvs as a bonus. LayerOGL.hip Quote Link to comment Share on other sites More sharing options...
yongbin Posted February 18, 2011 Author Share Posted February 18, 2011 Thank you, LaidlawFX! Sorry about my late reply. I leave with my computer for several days. That hip is very helpful. But I think number of the UVs are too much. So, I've changed some part of it. Please check it and feed back. withparticle.hipnc Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 18, 2011 Share Posted February 18, 2011 (edited) Thank you, LaidlawFX! Sorry about my late reply. I leave with my computer for several days. That hip is very helpful. But I think number of the UVs are too much. So, I've changed some part of it. Please check it and feed back. You can do it that way, no problem. The multiple uv sets just allows you to use one shader, and let is show in ogl. If you are just doing sprites you can group points and assign shaders to them, too, if you want to use multiple shaders. Using sprites over copy stamped grids at a basic level will be cheaper to render and in your scene. The only difference is do you want the control of individual shaders, and whether the overhead of more shaders vs the extra attributes is going to cause delays at render time. If you archive your geo, and shaders, the shaders become the only over head. The extra attributes get wiped. Also you could use the local override of a material sop of the color map and then copy stamp random a set of different materials. Edited February 18, 2011 by LaidlawFX Quote Link to comment Share on other sites More sharing options...
