Conditional statement strings
rob
Hi List,
Not sure I even have the correct terminology for the title. I wondered how I could evaluate a parameter in a string. Something like
if( toggle ABC is off , then use string parameter X , otherwise use string parameter Y )
. A simple example could be
../if(`chs("customname_toggle1")`== 1,`chs("list_customnamedl")`,`chs("list_objectname1")`_obj
I would be interested in the correct workflow and if its even possible !
Rob
Edited by rob
Hi Tomas,
Thanks for the answer I had a lead from someone else also.To push it further forward I decided to wrap it up in a multi param block list . It works to a certain extent ie
../`ifs(ch("custotoggle#") >= 1 ,chs("listobjectname#"),chs("customname2"))`_obj
But for each generation from the block list the # of each param does not evaluate. any ideas ?
Rob
Edited by rob
