how change a parameter from an other parameter?
supermac
hello all,
I learn again python on Houdini.. my knowledge in python are enough limited..
i search how i can change a parameter value if i'm in a other parameter..
i explain me:
if i'm into "ty" parameter of my object and i say:
if ch("tx") >= 10:
ch("tx").set(11)
or:
f ch("tx") >= 10:
ch("tx") = 11
there is no change..
i tried all i can imagine... but i can't find The solution..
i think that i must learn "logic" of python into Houdini..
First::
Please, someone can say me how i must write my code for change my parameter from an other parameter
and, there is a tutorial other that HOM docs from Houdini?
HOM docs is not for begginer like me!
Sorry for my english..
Thank you for your help
Best regard
The hou.ch() is a HOM alias to hou.Parm.evalParm() and is equivalent to the regular hscript expression function ch(). It returns a value. Your conditional statement is okay but your attempts to set the channel are wrong. To change a parameter you need to do something like this:
parm("tx").set(11)
