siachrek Posted February 26, 2011 Share Posted February 26, 2011 Hi is it possible to align a object to a curve that is being animated on a carve node?I have a curve that grows over time using a simple carve op and I wanted a different object to follow it, but at the object level.Think of it as a small bud at the end of a growing tube.Normally I do this by using the align sop and everything is in one object.The curve and the following geo.This time I want to keep the object seperate from the curve.Tried to search for how to do accomplish this but i am stumped. Quote Link to comment Share on other sites More sharing options...
anim Posted February 26, 2011 Share Posted February 26, 2011 each object has Parameter named Path Object (in Transform Tab) just drag&drop you curve object there and set Position to 1 if you want your object at the end of the path Quote Link to comment Share on other sites More sharing options...
siachrek Posted February 26, 2011 Author Share Posted February 26, 2011 each object has Parameter named Path Object (in Transform Tab) just drag&drop you curve object there and set Position to 1 if you want your object at the end of the path Oh man Anim, you rock!That worked wonderfully. Quote Link to comment Share on other sites More sharing options...
