python lib in houdini 11 mac os x
Hey gang,
Long time subscriber not so often poster (stupid maya) but.. i was trying to get Houdini 11 running on my mac at home and ran into a snag.
It launches fine if I double click the app.icon. However when I try to run it from the command line terminal it doesn't like my Python install.
i'm old school enough to have a setup script to set all the right environment variables and it modifies the ${PATH} as well. that setup script was working fine for me in 9 and 10 and i could easily flip versions quickly if I needed to.. so I'm pretty sure it has to be something else.
I did install the "mac" python version for 2.6 and 2.5 from python.org
and I didn't work.
So i went to hconfig -H and found some options.
HOUDINI_PYTHON_BIN
HOUDINI_PYTHON_LIB
HOUDINI_PYTHON_VERSION
and on linux there is one for
HOUDINI_USE_HFS_PYTHON
which seemed like a golden star to be used... but alas it didn't help. None of them worked and I followed the instructions :)
I'm at work at the moment so i couldn't tell you off hand what the error was but it was something that end in lib
I found through some connections (thanks graham!) that I should try to use the python that comes with HOUDINI so $HFS/python
but that didn't work. I don't see a HOUDINI_USE_HFS_PYTHON in my mac install so that is no help.
I'm starting to think i need to upgrad to something newer than my OS of 10.5.8... but you got me.
Funny thing is I thought for sure that Houdini 11 used 2.6, but when the app.icon opens houdini and I go to the Python sell it says 2.5.1..... odd?
I'm geeky enough to want to use the terminal and not "double click" ....suggestions?
thanks in advance... and I'll update with the errors i get when I get back to my laptop.
-k
okay,
thanks for reading along :)
I went and messed with some of the links so /usr/local/bin and /usr/bin.....
Then i went and reinstalled the app.
Seems to be working now I'm not sure what the problem was but I've got my command line launching again.
-k
