hopbin9 Posted April 17, 2011 Author Share Posted April 17, 2011 Ok, I'm able to get good results as long as I'm sourcing the fluid from an object. Once I try to stream the fluid using a Particle Fluid Emitter node. It starts exploding just like before. This is driving me insane. I'm not sure why it's exploding on frame 1, but it seems that the particles are to close together when they birth or something like that, but nothing I try seems to fix it. Try the attached file. Enable the "Pouring" check box on the AutoDopNetwork. untitled.hip Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted June 23, 2011 Author Share Posted June 23, 2011 I'm returning to this problem again after a break. It's been a while and I forget where I was on this, but I'm going to try again. Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted June 24, 2011 Share Posted June 24, 2011 Hi!! This is a modified scene of probins9. The viscosity in SPH its fast and stable if you tweak the right parameters. This scene will be better with the help of a sticky property and more resolution; I have implemented the sticky property for SPH (it's fast and stable, and works very well with high viscosity SPH): Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted June 24, 2011 Share Posted June 24, 2011 (edited) Hi!! This is a modified scene of probins9. The viscosity in SPH its fast and stable if you tweak the right parameters. This scene will be better with the help of a sticky property and more resolution; I have implemented the sticky property for SPH (it's fast and stable, and works very well with high viscosity SPH): http://www.vimeo.com/23509302. SORRY FOR THE DOUBLE POST test05_modified.hip Edited June 24, 2011 by Pazuzu Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted June 24, 2011 Share Posted June 24, 2011 More viscosity!!! test05_modified.hip Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted June 24, 2011 Share Posted June 24, 2011 More Resolution And Viscosity!!! test05_modified.hip Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted June 24, 2011 Author Share Posted June 24, 2011 More Resolution And Viscosity!!! Very good. Your stuff appears very stable. Quote Link to comment Share on other sites More sharing options...
ikarus Posted June 24, 2011 Share Posted June 24, 2011 good solution for the stickyness alejandro, nice work Quote Link to comment Share on other sites More sharing options...
stooch Posted April 8, 2013 Share Posted April 8, 2013 the solution to this is a variable viscousity solver that is based on heat. so as you add heat, viscousity decreases, but heat discreases over time and viscousity increases. with a heat value taht is over some threshold you can actually make the particle freeze in place using object space. Quote Link to comment Share on other sites More sharing options...
