Deepak Posted March 27, 2011 Share Posted March 27, 2011 Hi, here are some of my recent experiments in Mantra. I am having some trouble regarding noise creeping in the shadows areas. help guys, any tips.. thanks in advance Deepak Relective Rings.hipnc Relective Sphere.hipnc Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted March 28, 2011 Share Posted March 28, 2011 In the Mantra Sampling settings lower the Noise Level from 0.02 to 0.01, and increase Max Ray Samples from 9 to 16 or 32. That should do the trick. Quote Link to comment Share on other sites More sharing options...
Deepak Posted March 28, 2011 Author Share Posted March 28, 2011 In the Mantra Sampling settings lower the Noise Level from 0.02 to 0.01, and increase Max Ray Samples from 9 to 16 or 32. That should do the trick. Thanks for the tip.. I got a Better render using following settings Pixel samples 7 * 7 Min/Max rays 1/12 Noise level .01 jitter 0.015 Reflect limit 2 Refract limit 2 Diffuse limit 1 color limit 4 Photon count 250000 My Machine specs are Intel i7 950 extreme edition 16 gb RAm Render time was 7.51 sec Do you think we can still bring down the render time on this one. Quote Link to comment Share on other sites More sharing options...
Nerox Posted March 28, 2011 Share Posted March 28, 2011 Render time was 7.51 sec Do you think we can still bring down the render time on this one. Is that like 7.51 seconds, or 7 minutes and 51 seconds? Guess it's the second one Quote Link to comment Share on other sites More sharing options...
Deepak Posted March 29, 2011 Author Share Posted March 29, 2011 Is that like 7.51 seconds, or 7 minutes and 51 seconds? Guess it's the second one .... My bad..My bad... its 7 min 51 sec. where do I hide Quote Link to comment Share on other sites More sharing options...
varomix Posted March 29, 2011 Share Posted March 29, 2011 Render time was 7.51 sec Do you think we can still bring down the render time on this one. Reduce the Sampling Quality on the Environment Light back to 1 that might not affect your render quality, and will bring the render time way low let me know if that helps Quote Link to comment Share on other sites More sharing options...
Deepak Posted March 30, 2011 Author Share Posted March 30, 2011 Reduce the Sampling Quality on the Environment Light back to 1 that might not affect your render quality, and will bring the render time way low let me know if that helps Dude you ROCK.. Render time came down to 3 mins 34 sec But I am still seeing some noise in the shadow area , If looked closely.. any tips on that regards Quote Link to comment Share on other sites More sharing options...
