inverting camera/scene transformations
I don't know the technical term for this, but I'm calling it a '3D pin of the camera'
Let's say I have a scene with grid, sphere, pyramid, box etc. Then we keyframe a camera to navigate the scene.
The end result I want is: what we see through the camera is exactly the same, only it is the camera that is still, and the scene is doing the rotation and translation.
Is this solved through transform expressions, chops? python?
Thanks in advance for any guidance.
howdy, this is pretty chill to do in houdini.
i'm sure there are lots of ways to do this, but i always find vops the easiest way to deal with matrix stuff. this example shows grabbing the camera xform with a vop sop and inverting it, then using a point expression to animate a null with this xform. if you parent all the objects in the scene under this null, they animate around the origin.
inverse_camera_xform.hip
you can use an object merge as well. specify your camera in the object transform and it will orient the scene along the -z world axis (as if your camera was pointing down the axis).
works like a charm
works like a charm
Can you also do the perspective transform? So it would flatten the scene to a plane with perspective distortion?
Oops this is easy http://en.wikipedia.org/wiki/3D_projection
Edited by kgoossens
  • 1 year later...
