create keys from a saved pose
pencha
I´ve saved a pose to a channel CHOP from a channel group (left click, motion effects/create pose), animated the character, and now I can´t find the way to create a keyframe from that saved pose at another frame.
Setting the export flag on the channel CHOP works fine, showing the desired pose while the flag is on, but I can´t find the way to copy the values as keyframes so that the pose becomes keyed and stays once I turn the export flag off.
The copy to export button seems to mean do exactly that, but I can´t get it to work on channels that are already animated, even if I set a key on all the scoped channels at the desired frame before clicking copy to export.
Any help appreciated
Thanks!
thanks edward!
Seems like i´ll have to delve into pythonland for this.
May I ask why it´s not implemented by default?
Ain´t it nice being able to have your keys "baked" back to keep keying by hand?
(e.g, "baking" a walk cycle from chops, to be able to make adjustments with the pose tool)
Am I missing something? As you may see I´m totally new to character animation workflows in H.
Thanks again
Edited by pencha
  On 4/8/2011 at 2:42 AM, edward said:
Then you can keyframe on these moved channels and have them drive your character.
The "moved channels" are the channels created on the Channel CHOP?
If so, I´d lose the ability to modify them using handles?
Thank you
  On 4/8/2011 at 8:03 PM, edward said:
No, it should still work when you select the objects in the viewport. The selection will trace through the CHOP exports and scope the ones on your Channel CHOP. Mind you, I haven't tried this in a while. :)
So THAT was messing my channel groups haha
It still works as you said.
Thanks!
