POP:get an attribute from particle by id in vex
sanostol
is ther a fast way with out looping through all particles to get the attribute of a particle by ID. for example I'm splitting of particles from the volume of instances and the only way (I'm aware of) to let them inherit the velocity of the source is to copy the velocity of the sourcparticle is right now to use poppointid($PARENT, "v", 0-2). But I would like to stay in VEX for speed reasons and I think it is easier to use.
Martin
Yes, but in vop context you can just import an attribute from a ptnumber, not from an id.
So I guess the solution is to change the way you copy your velocity to your particles. Not sure to understand how you are generating them, but I think make them inherits the velocity of their parents/emitters at birthing time should be easy. How are you emitting them ?
And the other but heavy solution is to do your particles simulations either with the feedback sop or within the sop solver to have more options than in pops...
Edited by Div
