Need to "merge" particles
lorduk
What I am doing is raindrops on the wall,
the idea is if the particles get close enugh both particles would get blended velocity - how do it I have no clue :ph34r:
At the moment I use interact POP with negative force multiplyer to attarct the particles toward each other, but the particle go right pass each other and separate again (thats no good) <_< so I use proximity to make sure when the particles are close enugh to "merge" but how can I read the velocity of the $NEAREST particle? :(
-Kaspar
