mtl2mat - Learning Python
michael
so I want to start learning python...
and I thought a good way to do it besides just poking around at work would be to do a little project that actually did something useful in Houdini.
last year I was cleaning up my computer crap and found I had lots of little obj+mtl files around that I had collected from all over the place and while I had occasionally used a few of the objs I'd never bothered to even look at the mtls.
so that's the project - make a converter for an mtl file that will build a Houdini material.
(if there already is one that's cool - it would be useful for people to have)
so my question to you strange people who lurk in the Shaders area of od[force] is this:
what kind of material should I build?
I don't really want to build a shader right from scratch but I'd like something that can accommodate everything that an mtl file might try to describe.
this is an example from a file format description I found (from 1995!)
# Material name statement:
newmtl my_mtl
# Material color and illumination statements:
# ambient reflectivity
Ka 0.0435 0.0435 0.0435
# diffuse reflectivity
Kd 0.1086 0.1086 0.1086
# specular reflectivity
Ks 0.0000 0.0000 0.0000
# transmission filter
Tf 0.9885 0.9885 0.9885
# illumination model
illum 6
# dissolve
d -halo 0.6600
# specular exponent
Ns 10.0000
# sharpness of the reflections
sharpness 60
#optical density
Ni 1.19713
# Texture map statements:
map_Ka -s 1 1 1 -o 0 0 0 -mm 0 1 chrome.mpc
map_Kd -s 1 1 1 -o 0 0 0 -mm 0 1 chrome.mpc
map_Ks -s 1 1 1 -o 0 0 0 -mm 0 1 chrome.mpc
map_Ns -s 1 1 1 -o 0 0 0 -mm 0 1 wisp.mps
map_d -s 1 1 1 -o 0 0 0 -mm 0 1 wisp.mps
disp -s 1 1 .5 wisp.mps
decal -s 1 1 1 -o 0 0 0 -mm 0 1 sand.mps
bump -s 1 1 1 -o 0 0 0 -bm 1 sand.mpb
# Reflection map statement:
refl -type sphere -mm 0 1 clouds.mpc
most of this seems reasonably clear (Ka, Kd etc)
but what about these goof-ball texture map options?
and the illumination models listed:
0 Color on and Ambient off
1 Color on and Ambient on
2 Highlight on
3 Reflection on and Ray trace on
4 Transparency: Glass on
Reflection: Ray trace on
5 Reflection: Fresnel on and Ray trace on
6 Transparency: Refraction on
Reflection: Fresnel off and Ray trace on
7 Transparency: Refraction on
8 Reflection on and Ray trace off
9 Transparency: Glass on
Reflection: Ray trace off
10 Casts shadows onto invisible surfaces
these seem like things people do in other ways now...
I had a quick look at the mantra surface node in the materials palette and it seems to have most everything I can decipher from the format description, and more (obviously), but is this the best way to go?
Ideally I'd want to make a material that does everything the mtl describes, that's first, but I'd also like to provide the user with a material that has the usual nice stuff to go beyond this (AOVs, SSS etc).
any advice on this would be great.
thanks!
thanks!
seems to me like the most user friendly + forward looking way to do this would be to dynamically build a vop network (a-la 'shader fx') using a surface model and some texture nodes. that seems to maximize flexibility and minimize extraneous nodes/parameters that might come from trying to manage this all at the 'shop' level rather than the 'vop' level. this seems like it would create a nice 'framework' for building a complete network based on the mtl data as a starting point.
the nice thing about doing it this way is that you could take a look at the python for 'shader fx' to get started :)
just my 2c
Nice idea Michael :rolleyes: Here is my thought:
Most of materials in .mtl files aren't very complex...i would say they are pretty simple. And the mantra surface is far more complex, with a lot of stuff, that you probably, never find in .mtl. So, maybe a good start will be to build a simple "surface model" otl,maybe some hand-written VOP OP, just to speed things up....
Anyway, good luck with that. I'm sure you'll love python.
