CSN0309 Posted May 4, 2011 Share Posted May 4, 2011 (edited) hi~guys i got a problem when launching Houdini on Ubuntu11.4....i try to fix~ but.... I have installed Houdini 11.0.701(apprentice) on Ubuntu 11.4, but when i run houdini in terminal, it shows a lists of error: "/opt/hfs11.0.701/hsvg/hsvg-real: symbol lookup error: /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0: undefined symbol: g_cclosure_marshal_VOID_VARIANT" Even with this error, i still can launch houdini on ubuntu, but i got no icon in houdini, all the icons just simply displays as a white square. so,do you know how to fix this? Is this a problem relates to Ubuntu? i already seeking for answer from some linux online communities, but i still can't fix it. anyone got idea how to fix this? thanks in adsvance Edited May 4, 2011 by CSN0309 Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted May 4, 2011 Share Posted May 4, 2011 hi~guys i got a problem when launching Houdini on Ubuntu11.4....i try to fix~ but.... I have installed Houdini 11.0.701(apprentice) on Ubuntu 11.4, but when i run houdini in terminal, it shows a lists of error: "/opt/hfs11.0.701/hsvg/hsvg-real: symbol lookup error: /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0: undefined symbol: g_cclosure_marshal_VOID_VARIANT" Even with this error, i still can launch houdini on ubuntu, but i got no icon in houdini, all the icons just simply displays as a white square. so,do you know how to fix this? Is this a problem relates to Ubuntu? i already seeking for answer from some linux online communities, but i still can't fix it. anyone got idea how to fix this? thanks in adsvance Wait for a build that is built for gcc 4.5. The libs that Houdini use are probably compiled with gcc 4.5 in natty making it incompatible. Quote Link to comment Share on other sites More sharing options...
Alanw Posted May 4, 2011 Share Posted May 4, 2011 (edited) The gcc 4.4 builds should work fine on a system using Gcc 4.5. I responded to your thread on sidefx.com. I suggest you check there. http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=22119 edit: sorry, I am not sure if this is your thread on sidefx.com. Either way, it should help you. Edited May 5, 2011 by Alanw Quote Link to comment Share on other sites More sharing options...
