wire pin constraint
AdrianLazar
Hi guys,
I pretty new to Houdini and I'm having problems finding a way to attach one end of an wire to an animated null and the other end to another null that's static. Both null are parented to another null that has an animation.
I'm using pin constraints but I couldn't find a way to add in the goal location to global position of the nulls... Use animation doesn't work because the nulls have different animations.
Anyway, it's kind of hard to explain so I attached an example.
Many thanks,
Adrian
curve_simulation.hipnc
