ryew Posted May 9, 2011 Share Posted May 9, 2011 Hi guys, I'm relatively new to Houdini and trying to create a system that will take a piece of geometry (we'll call it "the chunk") and cookie it from a base geometry, both for eventual use in DOPs. I'm starting out simple with a scaled box for the chunk and another slightly higher-res and tweaked box for the base geo, and am running into some problems. The implementation I have in mind is basically: 1. Scatter points along the topmost outer perimeter edge of the base geometry 2. Copy stamp the chunk to those points 3. Cookie the chunk from the base geo and vice-versa for use in DOPs I'm running into a few problems with this that I'd appreciate any help on sorting out: 1. Scattering points along the topmost outer perimeter edge of the base geometry is a bit tricky, in that I can't manage to isolate that perimeter edge for scattering; I am instead using a popnet that seems to stick to that edge when Geometry Source is set to Edges(random)/(ordered) but they clump up pretty quick and make the copy-stamped chunks do likewise. I've tried using a scatter node at SOPs level, but that scatters points on the entire surface, not just the edges so currently the popnet source node is the best solution I've found 2. Because of the above problem, when I cookie the chunks against the base geo I get a lot of ugly geometry artifacts; holes, overlapped faces, etc. I've tried increasing the resolution of both pieces of geo but this doesn't seem to help (I'm guessing because the overlapped points/chunks are just too error-prone, which I completely understand!) Attached is an image of the problem and my current WIP; any advice the group can give me would be appreciated Thanks R topPerimeterEdgeCookie_v02.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted May 10, 2011 Share Posted May 10, 2011 here is what you can do 1. isolate top edge, then extrude slightly (only edges) to get tiny polygons, then scatter will work 2. if you are dealing with many pieces you cannot use one cookie for all, you need to use foreach sop to union overlapping first then you'll probably get several larger pieces so you'll need to use foreach to subtract them one by one from the base geometry and another to intersect them with geometry and merge together for the cut out pieces and increase resolution first to get better result and because this is cookie sop, there can still be errors, but this will at least work sometimes here is modified file to show above mentioned workflow topPerimeterEdgeCookie_v02_fix_kindOf.hipnc Quote Link to comment Share on other sites More sharing options...
ryew Posted May 11, 2011 Author Share Posted May 11, 2011 Thanks for the tips and workaround, Tomas Switching to a foreach SOP sounds like a good/cleaner way forward, I will definitely factor that into my graph soon. I think I may have figured out a way to get the clean perimeter edge I was after by using a carve SOP. From what I can see in my simple example, it appears to reduce the base geometry to just the outer edge that I wanted so I was able to use a scatter instead of a popnet. Hopefully this solution holds up for more complex geometry; at the moment it looks promising! Thanks for your help and advice, much appreciated -R topPerimeterEdgeCookie_v03.hipnc Quote Link to comment Share on other sites More sharing options...
