group to attribute .. ( python code )
zarti
hi all ,
yesterday i was working with profiles of a window. i needed to Sweep and Skin them, while preserving the manually assigned group names to later apply materials .
at the beginning, the ForEach SOP wasn't giving me the results with For's Each Group option . Each Attribute Value has always been 'kind with me' . =)
after searching in forums i didn't found something or felt tired and .. i gave Python a try .
here there are those lines pasted :
# This code is called when instances of this SOP cook.
geo = hou.pwd().geometry()
# Add code to modify the contents of geo.
groups = geo.primGroups()
group_list = []
for group in groups :
    group_list.append( group.name() )
#print group_list
mat_attrib = geo.addAttrib( hou.attribType.Prim, "group", "")
for group_name in group_list:
    for primitive in geo.iterPrims():
        if geo.findPrimGroup( group_name ).contains( primitive ):
             primitive.setAttribValue( mat_attrib, group_name )
create a new operator type > python type > geometry operator and paste this in the Code tab.
the attribute name is 'hard coded' to "group", but you can easily create a string input parameter for it.
... and so , my manually named groups 'survived' passing through foreachs , sweeps and skins =)
hope this wd help someone else in other cases too ..
attached pics shows what i was doing ...
That looks cool. Nice rendering by the wall.
thanks !
beside the glass , all other shaders are colored irradiance vops , mixed with lambert ( 10-15% ), just to slightly catch the shadows of a single point light and 'naturally' shade the models .
i'm doing few short animated illustrations .
