yongbin Posted May 17, 2011 Share Posted May 17, 2011 Hi all. When you see a motion blur menu on Geometry's instance tab, there are two selection types. Compute sub frame and point velocity. Can I add them? I have sequence of geometry of a bat. The bat flaps it's wing. So i need sub frame motion blur. But when instancing it to moving particles, I need point velocity, too. So i want add there velocity. Is there a way? Thank you. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted May 17, 2011 Share Posted May 17, 2011 I think the point velocity option means it will use the velocity attribute on any and all points. Just make sure that the animated bat has velocity per point in the cache. If it doesn't already then use a trail SOP with the mode set to calculate velocity and write out the cache again. Quote Link to comment Share on other sites More sharing options...
yongbin Posted May 24, 2011 Author Share Posted May 24, 2011 i tested it. and ye you are right.. i missed it. thank you! Quote Link to comment Share on other sites More sharing options...
