Setting "Output Transform" reliably on Object OTLs/HDAs
Hi all,
I have a problem with my Object OTLs -- how do you set your Output Transform to something other than "Input 1" reliably? It seems if I save the OTL with this set to a value I like, half the time it doesn't get set correctly on newly created. Am I missing something?
Or do I have to slap opparm/parm.set() into the OnCreated to do it manually?
Thanks,
Jason
I am curious about this too
However, I have used OnCreated event to set it on my all obj assets with no problem so far
the same problem is with Autoscope function on default parameters on subnet, they cannot be unset in HDA definition since they are greyed out, so I am un-setting them in OnCreated too
