Offset start frame
Hi, I had this sequence where a hose shoots out water with terrain and all that. However, I did not want the water to be release on the first frame, it will be release on the 100th frame instead. When I key 100 in the 'start frame' option, dopnet node on obj level and I also try keying 100 in the 'creation frame' option, rbdobject node inside dopnet, it did not work. Everything in the viewport vanish when I play the sequence. Can anybody help me with this?
Thank you.
i tried all the creation frame and it didnt work and as I had smoke container for my fluid, whenever I play with the creation frames, the smoke container will snap to the origin. How can i fix it?
The container has a parameter to control the location. If you don't set it to something then the default is at the origin. If you can post the scene it might help for troubleshooting.
