foreach on groups
sanostol
assuming that your stamp varibles on foreach are set to default
in H11 you can do just:
`stamps("..", "FORVALUE", "")`
it contains group name when working on groups
in H10 you need to use (if I recall correctly that back then FORVALUE variable just contained index)
`arg(primgroupmask(opinputpath("..",0), chs("../groupmask")),stamp("..", "FORVALUE", 0))`
in H11 if you need just index there is variable named FORIDXVALUE by default
where are you using it?
here is a little scene using it in Font SOP inside foreach
EDIT: of course you need to look at it when outside the foreach, the easiest method is to pin the viewport when outside, then dive inside for modifications and you can see the result in the pinned viewport
foreach_groupname.hipnc
Edited by anim
  • 11 months later...
  • 9 months later...
