How to make Cloth Model in SOP with wrinkle?
ghang
Hi, I have a question.
I am trying to make cloth modeling in SOP to archive nature look, but i face problem in making wrinkle.
I try:
point jitter
mountain
with different parameter, but it create 1 way direction wrinkle, i would like to know how to make multi-direction to look nature.
thank you for reply.
cheers
howToMakeCloth.hipnc
Displace in uv space for wrinkles or other surface deformations.
See the attached scene file for a simple set-up that adds general noise to a sphere. It shows you how to add a SOP attribute and paint in to it as a mask. The UV Brush SOP can be used to stretch the uv's around as well which I quickly threw in there.
It is common to copy over the uv's in to a new custom set and then sculpt those and use those to drive the noise.
displace_in_uv_space_wrinkles.hip
  • Like 2
thanks for your reply and the file, i will try to study more into the VOPSOP. I very appreciate your notes in the file.
thank you
cheers
  • 1 month later...
