water sipping into carpet
Hi all,
I really need some help here. I have to do a shot with water spilling onto carpet and then sips into the carpet. I already did the cg carpet in houdini. I was wondering what is the best way to do the water sipping into carpet effect? :unsure:
FLIP with custom velocity field so that the particles slowly sinks through the carpet instead of just colliding and attribute transfer to affect the rugs shader to get a more wet look?
EDIT: Guess the hard part is making it both splash and sink at the same time.
Edited by Erik_JE
  • 4 weeks later...
Thank you! I will give it a try :)
