roughsporty Posted June 18, 2011 Share Posted June 18, 2011 I have a prefractured object which breaks appart in the way it is designed for (first hit). In the simulation the peaces should break automatic like in "make brakeable" for the second and third hit. So how would I do this? Quote Link to comment Share on other sites More sharing options...
mawi Posted June 18, 2011 Share Posted June 18, 2011 I have a prefractured object which breaks appart in the way it is designed for (first hit). In the simulation the peaces should break automatic like in "make brakeable" for the second and third hit. So how would I do this? You can count hits with a modify data DOP and then do a check in the enable fracturing parameter. countHits.hipnc Quote Link to comment Share on other sites More sharing options...
