blur959 Posted June 25, 2011 Share Posted June 25, 2011 Hi all, Anyone knows what is wrong with my system? The terrain doesn't break. I already created velocity in my system. Many thanks for all help rendered. ripple fracture test_v002.hip Quote Link to comment Share on other sites More sharing options...
mawi Posted June 25, 2011 Share Posted June 25, 2011 (edited) Hi all, Anyone knows what is wrong with my system? The terrain doesn't break. I already created velocity in my system. Many thanks for all help rendered. Since you are having animated attributes(v) on the geometry you are reading in sopgeo1 node. You will have to set the SOP path parameter in that node to set always. Also the field force is by default set to look for a vector attribute called force. You are trying to use the velocity attribute so change the Force Attribute to v on fieldforce1. Edited June 25, 2011 by mawi Quote Link to comment Share on other sites More sharing options...
blur959 Posted June 30, 2011 Author Share Posted June 30, 2011 Since you are having animated attributes(v) on the geometry you are reading in sopgeo1 node. You will have to set the SOP path parameter in that node to set always. Also the field force is by default set to look for a vector attribute called force. You are trying to use the velocity attribute so change the Force Attribute to v on fieldforce1. Hey thanks man, problem solved. Quote Link to comment Share on other sites More sharing options...
