Barakooda Posted July 6, 2011 Share Posted July 6, 2011 (edited) I`m try to create something tron2.hipnc that look close to this one I`m stuck specially in the beveling part. any idea help hints other ways of doing it are welcome ! B. Edited July 6, 2011 by Barakooda Quote Link to comment Share on other sites More sharing options...
smaugthewyrm Posted July 6, 2011 Share Posted July 6, 2011 (edited) i've approached the bevel with a curve cross section. see attached hope this helps! see the stickies. tron2.hipnc Edited May 26, 2012 by smaugthewyrm Quote Link to comment Share on other sites More sharing options...
Barakooda Posted July 7, 2011 Author Share Posted July 7, 2011 i've approached the bevel with a curve cross section. see attached hope this helps! see the stickies. Thanks mate! i added the Ai file i dont think its spline close\open issue, but take a look. (i save it as CS version, CS3 not works for me) tronHcopy.rar Quote Link to comment Share on other sites More sharing options...
smaugthewyrm Posted July 7, 2011 Share Posted July 7, 2011 as seen in the upper right corner, houdini seems to insist on creating a line where the art has none. when using a true type font, you at least have a 'hole' checkbox to remove that line. with original artwork, i have not found a solution yet. i will however try 2 separate ai files. one is the outsides one is the insides. extrude both and then use a cookie sop to cut out the holes. maybe that will work. lol. Quote Link to comment Share on other sites More sharing options...
Barakooda Posted August 2, 2011 Author Share Posted August 2, 2011 Take a look. http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=22608 Quote Link to comment Share on other sites More sharing options...
smaugthewyrm Posted August 17, 2011 Share Posted August 17, 2011 e-gads it takes a lot of work to bevel illustrator shapes. that thread was very interesting. i've downloaded the hip/nc shares so now i've got a bit to check out. one bit i've noticed on the extrude sop, when using a profile for beveling, turn off "fuse points". i've installed H11.1.02 last night so it maybe some of these issues have been addressed. Quote Link to comment Share on other sites More sharing options...
