Infinite recursion in a script?
kursad
Hi
I am getting infinite recursion error(in the editor) in this simple Python code. I am putting this code in the X rotation of an object. Is it possible that the "origin" command causing this?
import math,hou
PI=3.14
v=hou.Vector4()
sphere=hou.node("/obj/sphere_object1")
box=hou.node("/obj/box_object1")
vs=sphere.origin().normalized()
vb=box.origin().normalized()
vd=vs[0]*vb[0]+vs[1]*vb[1]+vs[2]*vb[2]
degree= math.acos(vd)
return degree*180/PI
What object are you putting this code in? If it is either the box or the sphere then you will get the recursion error since it is trying to set the transform while reading the transform at the same time.
As for your code, since you are just doing a dot product and converting to an angle between the vectors, you could replace the last 3 lines with a simple return vs.angleTo(vb) since it will perform the operations for you. You also wouldn't need to normalize.
graham, I am putting in the X rotation of the box. I assumed that the rotation of the box might be independent of its transformation, although obviously it is a matrix operation. I am wondering what would be the right way to set this up then? Read the values in previous frames and set at the current frame maybe?
I can use Chops as well I was just trying to set this up with Python lines.
Ok thanks for the tip. I was not aware of those methods.
thanks
