Bin Posted July 12, 2011 Share Posted July 12, 2011 Hi guys, I started learning a bit about wire and got a problem. after baking the .sim file out, it's quick to set initial state on the DOP network, but, what if I want it to manually tweak some points(add an edit SOP) at a particular frame, and want the simulate start from just this tweaked shape? the quick example file below is just a bunch of lines copied onto a poly sphere, then turned into wire and simulated. the DOP network only reads .sim file as the initial. Is there a way to turn the edited geo into a .sim file that the DOP network can read, or other setups can work the way around? thanks wireTest.hip Quote Link to comment Share on other sites More sharing options...
anim Posted July 12, 2011 Share Posted July 12, 2011 there is Initial Pose parameter in Wire Object which will take your edited SOP and use as initial pose Quote Link to comment Share on other sites More sharing options...
Bin Posted July 12, 2011 Author Share Posted July 12, 2011 (edited) there is Initial Pose parameter in Wire Object which will take your edited SOP and use as initial pose well, I put a file SOP to write out the tweaked geo after edit SOP, put another "file2" SOP to read it back, then put the file2's path into the pose parameter of the wire object, but the wiresolver gives error saying geometry topologies do not match.... but all I did int edit node is just translating the position..... need more help here... wireTest2.hip Edited July 12, 2011 by Bin Quote Link to comment Share on other sites More sharing options...
