derm Posted July 13, 2011 Share Posted July 13, 2011 Hello! I've had this question for a very long time and kind of ignored it. So I figured I'd finally ask it because I'm sure it's simple. I'm working in a POP network right now. I've got a rotation node. When I middle click the node I see that there are attributes: v, accel, pstate, id, etc... Well I'm wondering how I can access the values of some of these nodes to be later used with testing conditions and bla bla bla? I know that a lot of attributes are generally just capitalized with a '$' in front of it, but for example, $PSTATE doesn't seem to exist. Thanks! Quote Link to comment Share on other sites More sharing options...
old school Posted July 13, 2011 Share Posted July 13, 2011 (edited) You can use the poppoint () to reference pstate directly but I rarely use this expression. Use the Attribute POP to first create the attribute mapping for the integer type "pstate" attribute first and then you can use it directly: $PSTATE. See the attached file for an example on how to use the Attribute POP to create the mapping and then use this to group and color points when pstate = 2 or about to die. attribute__group_color_by_pstate.hip Edited July 13, 2011 by old school Quote Link to comment Share on other sites More sharing options...
derm Posted July 13, 2011 Author Share Posted July 13, 2011 (edited) You can use the poppoint () to reference pstate directly but I rarely use this expression. Use the Attribute POP to first create the attribute mapping for the integer type "pstate" attribute first and then you can use it directly: $PSTATE. See the attached file for an example on how to use the Attribute POP to create the mapping and then use this to group and color points when pstate = 2 or about to die. Oh wow, thank you very much! <edit> Ah awesome, I just looked at the file. That's exactly what I was looking for. So easy. Thanks again! Edited July 13, 2011 by derm Quote Link to comment Share on other sites More sharing options...
