Batch render geometry node
I have a hip file with several out geometry nodes which generate different geometries at each frame.
I would like to batch (command line) my houdini file on a renderfarm. I don't care about pictures or Mantra job, geometry nodes are my only goal.
We have our own dispatcher in my company, and I just would like to execute some out-geometry nodes in my hip file.
Is there a way to do that ? What is the classic worklow ? Because in the documentation I can only see Mantra or Simulation batch info ;(
This is the first production I do with Houdini (we generally use Maya, and even if I know a bit Houdini, I have never used it in a production environment, network, renderfarm etc...) and I'm a bit lost on batch / renderfarm issues with houdini and nobody can help me here.
So, I'm really interested to be advised about networking setup with houdini in different studios.
Thanks in advance !
So, basically you want to execute a csh/bash/python script on a farm. There is one, called hrender that comes with Houdini (csh):
hrender -d /path/to/driver scene.hip
You can manage your own script and execute it with hscript (i.e. hscript script.cmd). The easiest one:
mread test.hip
render -V /path/to/driver
quite
or python (hython script.py)
hou.hipFile.load("scene.hip")
hou.node("/path/to/driver").render()
Hope, it's enough.
skk.
Do you know what is the license policy of sideFx about those batch process ?
hscript/hython requires its own license or can eat Houdini's one:
http://www.sidefx.com/index.php?option=com_content&task=view&id=385&Itemid=19
It costs quite a bit, but on the over hand, it's fully working Houdini, which can simulate, bake out, comp or render ifds.
skk.
btw: on the workstation with Houdini Master/Escape running, hscript won't take any license, but will keep one even after Houdini GUI will quit.
