ramp maximum value
Tranguz
Sorry, a novice question about ramps. I was trying to get the maximum value of a ramp (Spline Ramp) with an expression using Python. How do i cycle between ramp points?
ramp.eval() returns an object containing keys and values, so along this line:
ramp = node.parm("myramp").eval()
maximum = max(ramp.values())
for x in range(len(ramp.keys())):
    print ramp.keys()[x]
    print ramp.values()[x]
etc.
hth,
skk.
Oh Thanks for your help SYmek. Now I got it!
So eval() method in hou.Parm class with a referenced ramp parameter doesn't give you a int, float, or str value but an instance of hou.Ramp from which I can easily obtain the maximum ramp value from the values() tuple!
Thanks a lot!
Edited by Tranguz
