smaugthewyrm Posted July 18, 2011 Share Posted July 18, 2011 regarding rendering with verbosity level 4 / alfred style progress enabled would someone please explain the render time syntax below. lol. using my stopwatch the render time was about a minute and a half from my click... so '1:31.06r' appears to the time in minutes, but why is there an 'r' suffix? is the suffix r for 'render'? kindof redundant considering the beginning of the line. how about the other measurements on that 'render time' line thanks in advance. example: Render Time: 9:44.64u 26.77s 1:31.06r Memory: 441.61 MB of 11.10 GB arena size page rclm : 113692 flts: 0 # swaps : 0 blocks in : 0 out: 18 switch ctx: 11 ictx: 5341224 Peak Geometry Objects: 3 Quote Link to comment Share on other sites More sharing options...
symek Posted July 18, 2011 Share Posted July 18, 2011 This comes from a C standard and Unix kernels: http://stackoverflow.com/questions/556405/what-do-real-user-and-sys-mean-in-the-output-of-time1 2 Quote Link to comment Share on other sites More sharing options...
smaugthewyrm Posted July 18, 2011 Author Share Posted July 18, 2011 ok. perfect. i love this forum. real is what i was looking for. 'wall clock time' Real is wall clock time - time from start to finish of the call. This is all elapsed time including time slices used by other processes and time the process spends blocked (for example if it is waiting for I/O to complete).User is the amount of CPU time spent in user-mode code (outside the kernel) within the process. This is only actual CPU time used in executing the process. Other processes and time the process spends blocked do not count towards this figure. Sys is the amount of CPU time spent in the kernel within the process. This means executing CPU time spent in system calls within the kernel, as opposed to library code, which is still running in user-space. Like 'user', this is only CPU time used by the process. See below for a brief description of kernel mode (also known as 'supervisor' mode) and the system call mechanism. Quote Link to comment Share on other sites More sharing options...
