Michael Chiang Posted July 23, 2011 Share Posted July 23, 2011 Making 'SOP_Star.o' and 'F:/360data/impdata/mydoc/houdini11.0/dso\SOP_Star ll' from 'SOP_Star.C' Failed to run E:\VC8\VC\VC\bin\amd64\cl with error 2: The system could not find the specified file... why?? tool:visual studio 2005 x64 system:win7 cpu:Intel core i7 920 do i need to by a AMD64bit CPU?? Quote Link to comment Share on other sites More sharing options...
edward Posted July 24, 2011 Share Posted July 24, 2011 AMD64 is the x86 64-bit instruction invented by AMD. Intel later adopted it for their 64-bit x86 CPUs as well. So no, you do NOT need an AMD CPU. You probably didn't install the 64-bit compiler with Visual Studio 2005. It's not enabled by default. You must go through the Custom install and enable it. Quote Link to comment Share on other sites More sharing options...
Michael Chiang Posted July 24, 2011 Author Share Posted July 24, 2011 AMD64 is the x86 64-bit instruction invented by AMD. Intel later adopted it for their 64-bit x86 CPUs as well. So no, you do NOT need an AMD CPU. You probably didn't install the 64-bit compiler with Visual Studio 2005. It's not enabled by default. You must go through the Custom install and enable it. Thanks a lot!problem solved~ Like you said,I really didn't install the 64-bit compiler. Quote Link to comment Share on other sites More sharing options...
