reading point colors from .ply files
I have a .ply file that I am importing into a geometry node. The .ply format content is a point cloud with color information.
The points import and display. I also get 3 point attributes: diffuse_red[1], diffuse_green[1], diffuse_blue[1]
In details view I can see healthy numbers in those point attributes.
In a point sop I tried: add color $DIFFUSE_RED I get 'unable to evaulate expression'
My first thought is perhaps these point attributes from the import only look like floats but are really strings.
I've tried some hscript expressions using atof, point, and eval... no go, either I'm tripping up in syntactical errors or I'm barking up the wrong tree.
I'm just trying to map these attributes to point colors so I can see them in the viewport.
Thanks for any assistance.
easiest way is to use VOP SOP to combine your attributes to color (Cd)
see example file
or you can use Attribute Create to initialize variables for your existing attributes
fill in name: diffuse_red
local variable: DIFFUSE_RED (or any)
and uncheck Write Values parameter to just initialize the variable and not overwrite attribute's value
now you can use that variable in Point SOP for example
color_points.hip
