sabotage Posted July 31, 2011 Share Posted July 31, 2011 Hello guys can someone help me to setup alfred and renderman with houdini. I am trying to make it work under localhost but whatever I do it invokes netrender I am trying to make it to use local prman and the service local:PixarRender. If someone has a setup example it would be great thanks in advance. Quote Link to comment Share on other sites More sharing options...
crunch Posted July 31, 2011 Share Posted July 31, 2011 Hello guys can someone help me to setup alfred and renderman with houdini. I am trying to make it work under localhost but whatever I do it invokes netrender I am trying to make it to use local prman and the service local:PixarRender. If someone has a setup example it would be great thanks in advance. Try adding the alfr_command property. You'll see that it defaults to "netrender -progress %H". You should be able to change it to something else. Quote Link to comment Share on other sites More sharing options...
sabotage Posted July 31, 2011 Author Share Posted July 31, 2011 The problem it is calling the pixarNRM service I am trying to set it to local:PixarRender. And the changing the netrender to prman should work as a final option I will just edit the alfrerun.py . But still if someone get it to work so that It writes the ribs in alfred and then render them please share you knowledge thank you. Quote Link to comment Share on other sites More sharing options...
sabotage Posted July 31, 2011 Author Share Posted July 31, 2011 I have attached one of my thousand attempts to get the proper combination most of the time it just says servers busy. I just need to generate the ribs with something like immediate rib generation and after that alfred to render the frames it should be simple isnt it. test_alfred.hip Quote Link to comment Share on other sites More sharing options...
