expressions in inline function in VEX
envil
The inline VOP is for vex code, not expressions.
To get the result of the chopi expression in an an inline vop, you could drop a parameter vop, use the chopi expression in that parameter at sop level, and then wire the parameter vop into the inline vop.
Yes, but I need to read CHOP channels per-pixel.
I need to analyze the image in CHOP and return from CHOP the pixel values.
you need this for COPs?
if so
make grid of points in SOPs with the same resolution as your COP image (m*n points to represent m*n pixels)
then use Channel SOP to easily get data from CHOPs
and then in VOP COP you can easily import attribute from SOP point to pixel
if so
Yes! Thank you!
Cool Idea! +)
Well that there is someone who always looks at the problem from another angle!
Edited by envil
