Font-Sop Python
resonanz
I am sure it is a simple problem but I cannot find the solution, so here is the question:
I put some code into the text field of a Font-Sop and I want to return the values. My problem is that it allways returns the whole code and not just the value. In Hscript I can use the backsticks and put the expression inbetween but how do I do this in Python?
Thanks in advance!
Thanks in advance!
Im not infront of houdini now but if I remember correct you need to keyframe a string parameter when using python in it.
Edited by mawi
  • 1 month later...
1. Go to frame 1
2. Right-click on the Font SOP's "Text" parameter. Choose Channels and Keyframes > Set Keyframe
3. Right-click on the Font SOP's "Text" parameter. Choose Expression > Change Language to Python
4. Right-click on the Font SOP's "Text" parameter. Choose Expression > Toggle Expression
5. Right-click on the Font SOP's "Text" parameter. Choose Expression > Edit Expression. Put in your python code. eg. hou.pwd() <and click Apply>
  • Like 2
