enviroment map error
After sticking in an environment map onto an environment light, (which for some odd reason, said it couldn't find it) and deleting the light, mantra is still looking for that HDR texture file. This causes my render to have some strange artifacts. Even after deleting the light and the mantra node, and even restarting houdini, this error occurs. How can I find this path and delete it so mantra stops looking for it? Thanks.
Edited by DeehrBYU
This have never happened to me but can probably be resolved by deleting your houdini11.0 directory in your home folder. The location of this depends on what operating system you are running.
Uhm, right! Anyway, I solved this by other means now...
