br1 Posted August 11, 2011 Share Posted August 11, 2011 Hi, I'm having problems on me fur rendering tests. I'm using version 11.0.831. I'm loading my file from an UNC path like //computer/work_directory/scene/myfile.hip. I played around with combing fur, adjusting densities and changing fur length. It is quite strange but if the add_furlength node is active when I try to render, mantra crashes after rendering a few tiles and pops an error message : UT_NetPacket::read: No such file or directory I tried to disable my firewall as I read that it could interfere with mplay and mantra, but I still get the same error each time. As soon as I set that node to be bypassed the render goes fine. I also tried using another attribcreate node the recreate the furlength attribute, but yet it still crashes the render. Anyone already bumped into this ? A workaround would be great. Cheers Bruno Quote Link to comment Share on other sites More sharing options...
