ehsan parizi Posted September 1, 2011 Share Posted September 1, 2011 Hi all; Is there any way to replace an object with another object at the same location? obviously we can use switch node to switch between 2 geometry but it doesn't replace the geometry at the same location! Let's say I have a box , that converts to 2 boxes (same size as the main box) and I want the new born box to repeat the same animation. the only problem is that I don't know how to make the new born box repeat the animation AT the same place that it's located right now! Quote Link to comment Share on other sites More sharing options...
sanostol Posted September 1, 2011 Share Posted September 1, 2011 i suggest You are better prepared in a simulated environment for that. I have no clue what Your animation looks like, so it is quite hard to tell, but the sopsolver can do that kind of stuff Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted September 1, 2011 Author Share Posted September 1, 2011 you're probably right, I've not used sopsolver that much. But the thing is I wanted to avoid using DOPs! Quote Link to comment Share on other sites More sharing options...
Macha Posted September 1, 2011 Share Posted September 1, 2011 Can you copy stamp? In other words, can you store the animation on the positions rather than the objects? Quote Link to comment Share on other sites More sharing options...
eyevex Posted September 2, 2011 Share Posted September 2, 2011 It sounds like this may be a job for CHops if we are talking about animated channel date. Its not toally clear what it is you are animating, how its animated etc... but in the example of the boxes they are simialr. It should be fairly simple to make a generic obect with the animation and use chops to retarget the channel data to another object --even easier if named similar with the same channels. Then a switch can be used for determining display. Quote Link to comment Share on other sites More sharing options...
Peter Quint Posted September 2, 2011 Share Posted September 2, 2011 Not exactly sure what you are aiming for - this may help http://www.vimeo.com/7488503 Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted September 6, 2011 Author Share Posted September 6, 2011 thank you all for your responses. I did it with Chops. although it wasn't that simple that I thought it would be. Thanks all again Quote Link to comment Share on other sites More sharing options...
