poppy Posted September 13, 2011 Share Posted September 13, 2011 Hi, I got a scene with animated machine gun firing. Created a location emitter, placed and parented to the gun barrel. Result - the whole set of particle transform after its parent and I got a laser beam. How can I free emitted particle from the parenting. Thanks Quote Link to comment Share on other sites More sharing options...
Rudinie Posted September 13, 2011 Share Posted September 13, 2011 On 9/13/2011 at 10:48 AM, poppy said: Hi, I got a scene with animated machine gun firing. Created a location emitter, placed and parented to the gun barrel. Result - the whole set of particle transform after its parent and I got a laser beam. How can I free emitted particle from the parenting. Thanks You should only animate (parented) the emitter, not the particles itself. So make sure your particles are in a seperate object. Quote Link to comment Share on other sites More sharing options...
poppy Posted September 13, 2011 Author Share Posted September 13, 2011 On 9/13/2011 at 10:58 AM, Rudinie said: You should only animate (parented) the emitter, not the particles itself. So make sure your particles are in a seperate object. Thanks, But how can I parent [bullet-obj]>[Popnet]>[locator] node to [Gun-obj] node I'm quite new to Hou Quote Link to comment Share on other sites More sharing options...
Rudinie Posted September 13, 2011 Share Posted September 13, 2011 On 9/13/2011 at 11:04 AM, poppy said: Thanks, But how can I parent [bullet-obj]>[Popnet]>[locator] node to [Gun-obj] node I'm quite new to Hou It's even easier if you set the source in your popnet to use parameter values and point to the sop that represents the barrel of the gun. I took the liberty to quickly make a working example for you. bullets_from_gun.hipFetching info... Quote Link to comment Share on other sites More sharing options...
poppy Posted September 14, 2011 Author Share Posted September 14, 2011 On 9/13/2011 at 11:47 AM, Rudinie said: It's even easier if you set the source in your popnet to use parameter values and point to the sop that represents the barrel of the gun. I took the liberty to quickly make a working example for you. Thanks man! That enlightened me Jesus, I love this forum Quote Link to comment Share on other sites More sharing options...
