StarfishRap Posted September 15, 2011 Share Posted September 15, 2011 Hi all, I'm working on a project which requires the character(shoelace) to form complex shapes. I got my shoelace rig up through follow curve. So my question is how do I make the shoelace follow the deformations of a curve? So that ultimately I could make the shoelace travel across a pre define shape hence forming the shape. This is the effect I'm going for but with my shoelace instead. Things that I have tried. Setting path object for my controls, it moves in an unpredictable manner. Setting path object for only my root control, moves predictably but the geometry is static. Also I'm having some deformation issue where the bends are too sharp. Is this due to the weighting? I've tried increasing resolution of my shoelace. I've tried using subdivide node within the captured geometry node. I've tried increasing number of bones. Too much bones and the capture is not as accurate. Link to my blog where I post my W.I.P http://projectsesi07.blogspot.com/ Thanks for your time. shoelace_geo_v008.hip Quote Link to comment Share on other sites More sharing options...
edward Posted September 16, 2011 Share Posted September 16, 2011 Also I'm having some deformation issue where the bends are too sharp. Is this due to the weighting? Yes, because there's not enough overlap in the weighting of your points from adjacent bones. One way is to just smooth out all your weights using CaptureLayerPaint but I would use CaptureProximity (instead of Capture) and just manipulate the dropoff to the smallest value that gives a decent basic deformation. Quote Link to comment Share on other sites More sharing options...
StarfishRap Posted September 19, 2011 Author Share Posted September 19, 2011 (edited) Hello Edward, Thanks for your reply. Would it be advisable to use more bones or less bones? Also worked on the shoelace shader. Any feedback is appreciated. Edited September 19, 2011 by StarfishRap Quote Link to comment Share on other sites More sharing options...
edward Posted September 20, 2011 Share Posted September 20, 2011 Would it be advisable to use more bones or less bones? You should use the minimum number of bones while still giving the desired deformation. Quote Link to comment Share on other sites More sharing options...
StarfishRap Posted September 20, 2011 Author Share Posted September 20, 2011 Thank you for your reply. CaptureProximity works like a charm! Quote Link to comment Share on other sites More sharing options...
