puma.snyder Posted October 7, 2003 Share Posted October 7, 2003 Hi, got another problem I have the following setup (see attachment). 9 points with an attribute "HEIGHT" (describing the height for each point) An attribCreate sop which animates the existing attribute "$HEIGHT*chf("../add1/pt0x", $F)" A point sop with $HEIGHT in ty No, how can I achieve the following animations (in houdini select, so no chops) Move each point to its final position 1: with the next point always starting 1 second after the previous started 2: with the next point always starting after the previous reached its final position 3: but instead of individual points move each complete row (or column) to its target position using the methods described above 4: how to simulate the lag chop with expressions, so that (optionally) each point temporarily moves a bit above its final position Thanks in advance Achim animate.hipnc Quote Link to comment Share on other sites More sharing options...
AndrewVK Posted October 7, 2003 Share Posted October 7, 2003 1: with the next point always starting 1 second after the previous started delay.hipnc Quote Link to comment Share on other sites More sharing options...
AndrewVK Posted October 7, 2003 Share Posted October 7, 2003 Ooops...wrong expression....replace with $TY+fit($F,$START+$DELAY*($PT),$START+$DELAY*($PT+1)+$DELAY,0,$HEIGHT) Quote Link to comment Share on other sites More sharing options...
puma.snyder Posted October 7, 2003 Author Share Posted October 7, 2003 Wow, thanks Andrew! so 1= $TY+fit($F,$START+$DELAY*($PT),$START+$DELAY*($PT+1)+$DELAY,0,$HEIGHT) 2= $TY+fit($F,$START+$DELAY*($PT),$START+$DELAY*($PT+1),0,$HEIGHT) 3a (row by row) = $TY+fit($F,$START+$DELAY*wrap($PT, 0,3),$START+$DELAY*wrap($PT,0 ,3)+$DELAY*.5,0,$HEIGHT) 3b (row by row) with additional delay (small) per point $TY+fit($F,$START+$DELAY*wrap($PT, 0,3)+($PT*5),$START+$DELAY*wrap($PT,0 ,3)+($PT*5)+$DELAY*.5,0,$HEIGHT) 3c (row by row) with additional delay (high) per point $TY+fit($F,$START+$DELAY*wrap($PT, 0,3)+($PT*15),$START+$DELAY*wrap($PT,0 ,3)+($PT*15)+$DELAY*.5,0,$HEIGHT) >>> 3c causes the points in the next row to start, before the last points in the previous row have finished . I cant figure out how to modify this expression so this does not happen Any ideas here? 4= ??? well, this is nearly perfect, but I would like to have another option right now it takes for every point the same amount of time to reach its target position, how can I make them all travel at the same speed, so that points with a higher Height attribute take more time to reach final position ? Thanks again Achim delay3.hipnc Quote Link to comment Share on other sites More sharing options...
AndrewVK Posted October 7, 2003 Share Posted October 7, 2003 Hmmmm...may be this helps... PS its about: "right now it takes for every point the same amount of time to reach its target position......" If You want offset in time just modify expression: 0.8 + point("../sop11",$PT,"ddtime",0) for example You can also randomize speed attribute PSS cofee + cigarettes = Delete "attribcreate3" sop And replace "parameter1" vop with "constant" vop (float = 0) vexed.hipnc Quote Link to comment Share on other sites More sharing options...
puma.snyder Posted October 8, 2003 Author Share Posted October 8, 2003 thanks again Andrew that helped a lot Quote Link to comment Share on other sites More sharing options...
