colored volume shadow
Hi, Is there a way to cast a colored shadow from a volume object?
I'm not talking about volumetric-environment-light-rays effect.
The scenario is: a light cast a shadow of a volume object onto another object, like a ground plane, the shadow takes the color of the volume.
Like it would with transparent objects.
thank you
thank you
As a quick shot you just need to multiply opacity by inverse of a smoke color (AFAIK more robust solution would need further consideration). The default billowy smoke handles opacity as a float, not vector, but this is easy to fix. Pyro material has a shadow color parameter in place what indicates this is somehow hackish solution.
