Add Point
sparkChan
hi, I want to add selected points to the same group and not create a new one. but there is no options about this, I always add the selected points to a new group. so....?
thanks.
Depends on the situation! but you can add points to a group that already exists by editing the group. there's an edit tab in your group node. check it out
Edited by ehsan parizi
not this situation, I mean I select points in viewport and then add those point to existed group.
thanks
Select the group node in the network view, go to the viewport and press the backtick "`" key, the group node will disconnect, select the additional points by holding the shift and control keys, hit enter. I hope this helps. Of course this method is valid for every node that has to do with viewport selections.
Edited by Sifis
thanks, it works.
