Sample Takes script try
Hello world
Hi there,
I am trying to implement the below to execute two takes for reflection and specular passes.But dont know why the takes doesnt seem to take effect,but i dont get any errors and the script is working.Here is the code snippet of what Im trying.
hou.hscript('takeadd -c -p Main spec')
hou.hscript('takeautomode on')
#hou.hscript('takeinclude /obj/ *')
klig1.parm('shadow_type').set('off')
flig1.parm('shadow_type').set('off')
rlig1.parm('shadow_type').set('off')
hou.hscript('takeautomode off')
hou.hscript('takeadd -c -p Main ReflectionPass')
klig1,flig1,rlig1 are the variables for lights
thank you very much
Edited by Hello world
Weird mixture of python and hscript.
flig1.parm('shadow_type').set('off') <-- This is wrong.
hou.parm('/obj/flig1/shadow_type').set(0) <-- This is right.
flig1 = hou.node('/obj/flig1')
flig1.parm('shadow_type').set(0) <-- This also works.
Edited by Erik_JE
SAMPLE SCENE
sh=hou.node('shop')
msurf=hou.galleries.galleryEntries("mantrasurface")[0]
node=hou.node('/obj')
klig1=node.createNode('hlight','KeyLight1')
flig1=node.createNode('hlight','FillLight1')
rlig1=node.createNode('hlight','RimLight1')
klig1.moveToGoodPosition()
flig1.moveToGoodPosition()
rlig1.moveToGoodPosition()
#position the lights
klig1.parm('tx').set('536.254')
klig1.parm('ty').set('489.605')
klig1.parm('tz').set('-91.884')
klig1.parm('rx').set('-39.0293')
klig1.parm('ry').set('100.776')
klig1.parm('rz').set('9.132')
flig1.parm('tx').set('-356.148')
flig1.parm('ty').set('475.435')
flig1.parm('tz').set('-573.03')
flig1.parm('rx').set('-30.582')
flig1.parm('ry').set('206.504')
flig1.parm('rz').set('7.632')
rlig1.parm('tx').set('-540.86')
rlig1.parm('ty').set('402.254')
rlig1.parm('tz').set('596.632')
rlig1.parm('rx').set('-25.92')
rlig1.parm('ry').set('321.352')
rlig1.parm('rz').set('-4.37')
msurf.createChildNode(hou.node("shop"))
rp=hou.node('out').createNode('ifd','testmantra')
hou.parm('obj/KeyLight1/shadow_type').set(0)
hou.parm('obj/FillLight1/shadow_type').set(0)
hou.parm('obj/RimLight1/shadow_type').set(0)
hou.parm('shop/mantrasurface/diff_enable').set(0)
hou.parm('shop/mantrasurface/refl_objs').set(0)
hou.parm('shop/mantrasurface/refl_objs').set(1)
#dummyobjs
box = node.createNode('geo', 'box', run_init_scripts=True)
box.createNode('box')
bo=hou.node('/obj/box/file1')
bo.destroy()
grid=node.createNode('geo','grid',run_init_scripts=True)
grid.createNode('grid')
gr=hou.node('obj/grid/file1')
gr.destroy()
Hi erik,
Still I am getting some problems.Takes are not working perfectly.Few parameters still remain the same.
Yeah, the Auto Takes don't respond when setting parameters with python. I have no idea why. Maybe you need to explicitly add the parameter to the take as well. Never created takes through scripts before so can't help more.
EDIT: Yeah, you need to do takeinclude first before changing the parameter for it to pick it up.
http://www.sidefx.com/docs/houdini11.1/commands/takeinclude
Edited by Erik_JE
thank you very much for the reply.
But in my case,the changes are occurring for the only one pass.and for the 2nd or 3rd pass still the parameters remains same even after chnging
#adds a take
#sets to specular take
hou.hscript('takeset spec')
#make  it live
#include all the objects within the path defined
#changes
hou.parm('obj/testshop/mantrasurface/diff_enable').set(0)
hou.parm('obj/testshop/mantrasurface/refl_objs').set(0)
hou.hscript('takeset ReflectionPass')
hou.hscript('takeinclude /obj *')
hou.parm('obj/testshop/mantrasurface/refl_objs').set(1)
hou.hscript('takeset Main')
